ძველი მოთამაშე Posted January 31, 2012 Share Posted January 31, 2012 Patriot Extreme 4GB (2 x 2GB) DDR3 1600MHz ახლები 70 ლარი თავის ყუთით და ყველაფრით რა Extreme Performance PC3-12800 (1600MHz) Low Latency (7-7-7-20) Patriot Aluminum Bladed Heat Shield Technology to improve module module stability 100% Tested and Verified Lifetime Warranty RoHS Compliant Tested and compatible with Intel P35, X38 and X48 chipsets Model: PDC34G1600LLK Type: 240-Pin DDR3 SDRAM Capacity: 4GB (2 x 2GB) Speed: DDR3 1600 (PC3 12800) Memory Timings: 7-7-7-20 Voltage Settings: 1.9V Link to comment Share on other sites More sharing options...
