T.J. Posted October 6, 2012 Posted October 6, 2012 PATRIOT Viper Xtreme Series, Division 2 Edition 8GB (2 x 4GB) PC3-12800 (1600MHz) Low Latency Kit P/N: PXD38G1600LLK • Extreme Performance PC3-12800 (1600MHz) • Low Latency (8-9-8-24) • Voltage: 1.65V • XMP Ready • Equipped with an extruded aluminum shield build around a copper core to provide improved cooling • 100% Tested and Verified • RoHS Compliant • Tested on Intel® P67 platform Patriot's Viper Xtreme Series, Division 2 Edition memory kits are designed for Intel's® 2nd Generation Core™ processors. Engineered for PC Gamers and enthusiasts the Viper Xtreme Division 2's utilize a custom designed heatshield solution with an outer shield built around a copper core to provide enhanced cooling. Each module has 6 grams of copper at its core paired with extruded aircraft-grade aluminum outer shield. Built from only using the highest quality pre-sorted IC's available, they are rigorously tested and validated on the Intel® 6 Series platform to achieve maximum performance and stability. These modules are engineered to reach PC3-12800 (1600MHz) at 8-9-8-24 timings and are available 8GB kits (2 x 4GB). Each module is 100% hand-tested to quality assurance and is backed by a full-lifetime warranty and industry leading customer service სულ ახალთახალი, გაუხსნელი ყუთით. ფასი 65 ლარი / ფასი amazon.com_ზე 599 920 190 თემო
T.J. Posted October 6, 2012 Author Posted October 6, 2012 P.S. - ჩამოსვლის სავარაუდო თარიღი: 23 ოქტომბერი.
