DEEPCOOL ICE WIND PRO
Features
Equipped with multiple clips to support Intel LGA1366/1156/775 and AMD FX/AM3+/AM3/AM2+/AM2/K8.
4 sintered powder heatpipes conduct heat from the processor quickly to protect it from overheating.
Heatpipes are lined up in a straight line to improve air flow through the heatsink.
Patented Core Touch Technology(CTT) gives perfect contact with the CPU surface.
Dense aluminum fins arranged in sea wave shape allows optimum airflow for better cooling performance.
120mm fan with PWM function offers a perfect balance between airflow and noise.
Extra fan clips provided allow to add a second fan to form a push-pull config.
Intelligent side flow design further utilizes system airflow to improve computer case ventilation.
Application ForIntel Socket 130W
LGA1366/LGA1155/LGA1156/LGA775
Core i7/i5/i3
Core 2 Extreme
Core 2 Quad
Core 2 Duo
Pentium Dual-Core
Pentium D/Pentium 4
Celeron Dual-Core
Celeron/Celeron D AMD Socket 125W
FM1/AM3+/AM3/AM2+/AM2/940/939/754
FX X8/X6/X4
A8/A6/A4
Phenom II X6/X4/X3/X2
Phenom X4/X3
Athlon II X4/X3/X2
Athlon X2
Athlon/Athlon FX
Business Class
Sempron
Technical SpecOverall Dimension
140X83X157mm Fan Dimension
120X120X25mm Net Weight
650g Bearing Type
Hydro Bearing
Rated Voltage
12VDC Operating Voltage
10.8~13.2VDC Started Voltage
7VDC Rated Current
0.13±10%A(MAX)
Power Input
1.56W Fan Speed
500±200~1500±10%RPM Max. Air Flow
66.3CFM Noise
17.8~27.6dB(A)
ICE EDGE 400 XT
Core i7/i5/i3
Core 2 Extreme
Core 2 Quad
Core 2 Duo
Pentium/Pentium G
Pentium D/Pentium 4
Celeron Dual-Core
FX X8/X6/X4
A8/A6/A4
Phenom X4/X3
Athlon II X4/X3/X2
Athlon X2
Athlon/Athlon FX
Business Class
Sempron
100X86X126.5mm Fan Dimension
92X92X25mm Net Weight
585g Bearing Type
Hydro Bearing
Rated Voltage
7VDC Rated Current
0.11±10%A(MAX)
Power Input
1.32W Fan Speed
900±150~2200±10%RPM Max. Air Flow
39.58CFM Noise
17.8~28.1dB(A)
ა ესაა ამ ორი ქულერის მონაცემები და უკეთესი მირჩიეთ რა ფასი ერთნაირია
შეხების ზედაპირი როგორი ჯობია?
და კიდე ICE EDGE 400 XT უყენია 92მმ ფენი, ICE WIND PRO 120მმ
მაგ ორს შორის ICE WIND PRO უფრო წარმადია
მეორე ჯობია შეხების ზედაპირი უკეთესი აქვს თერმო მილაკები პირდაპირ ეხება ბირთვებს, საუკეთესო ტექნოლოგიაა ეგ
anu 2 xma ice wind pros
ეს 2 კაცი გასგებია სხვები რას მეტყვით ახალს?
  • 2 weeks later...
მეორე ჯობია სილამაზით :D
Cooler Master Hyper 212+ ვერცერთი ვერ ჯობს ?
ბარემ აქვე დავწერ
ამ ორს შორის რომელი ჯობია და ღირს თუ არა ზედმეტის გადახდა?
1. http://www.gitec.ge/p/12673/deepcool-fiend-shark
2. http://www.gitec.ge/p/12674/deepcool-ice-matrix-600
G3 ში უნდა ჩავდგა.
ვხურავ
